2016 Honda Accord Rear ABS Sensor problem
Old Oct 15, 2025 | 07:20 AM
dctaz37's Avatar
Default 2016 Honda Accord Rear ABS Sensor problem
We were driving along and all these warning lights came on at the same time: ABS, tire pressure, power steering and traction control. I have another post but decided to change the title in hopes it is less confusing and possibly get more help.
I picked up a scanner Autel Autolink AL619 (
" title="Amazon" target="_blank">Amazon
Amazon Amazon
. I bought all four replacement sensors in which the two rears are the same. Cleaned the hole many times as the new sensor was very hard to get it. It ended up breaking trying to get it in so I had to repeat the removal process. Cleaned a little more and eventually was able to install the second one I had. Now I get ABS sensor installed incorrectly error code 16-15. Any help please? Can you lube the outside of the sensor to get it in? I didn't want to wire brush/clean too much.
Old Oct 17, 2025 | 11:02 AM
dctaz37's Avatar
I tried another sensor, put it back together and same problem. Took the hub apart and found a ton of corrosion, see before and after pictures. Also the end of the bearing pack had a crack, should have snapped a picture. Put it back together and same error. I ordered a new hub as I don't know what else to do.
wings
Jan 6, 2012 03:14 PM
lmrj0030
Dec 25, 2011 08:19 AM
Wiley-X
Nov 30, 2011 06:15 PM
500$accord
Nov 28, 2011 09:30 PM
thelandlordsmm
Aug 17, 2009 08:48 AM
