94 Accord: ABS issues
Old Nov 30, 2011 | 05:13 PM
Wiley-X's Avatar
Default 94 Accord: ABS issues
My ABS light has been on for years. That really isn't an issue because I drove for years without ABS but I got the bug to fix the problem.
Digging through the maintenance records, I found a receipt from around the time that the ABS light first came on. I had asked the mechanic to look into the problem. The note on the receipt said that the right rear ABS sensor was bad.
So my first step was to pull the sensor and clean it. No joy.
Then I bought a supposedly good sensor but used sensor on Ebay and installed it.
Now the problem has changed. It used to be that I would drive a mile before the ABS light came on. Now the light comes on as soon as the car starts rolling.
Any thoughts?
Old Nov 30, 2011 | 05:35 PM
Check the codes again......what was the resistance on the old sensor?...not sure which (drivers/pass) you replaced.
Old Nov 30, 2011 | 06:04 PM
Wiley-X's Avatar
right rear. so passenger side rear.
Old Nov 30, 2011 | 06:15 PM
Check the codes again, could be a new one.......or the same that is something other than the sensor (connetion, wiring, ect). That is why I ask about the resistance reading of the old one.
fahad
Dec 31, 2013 07:47 AM
93Accord2.2
Nov 7, 2013 07:10 AM
DOC2011
Mar 10, 2013 02:06 PM
Ineedhelp
Jan 22, 2012 07:29 PM
GOT BOOST
Nov 2, 2009 08:32 AM
