2017 Accord - Battery temp sensor relocation
Old Aug 29, 2023 | 05:06 PM
xsvspd81's Avatar
Default 2017 Accord - Battery temp sensor relocation
Hi everyone. I am looking to improve the ground cables for the charging system. The battery has a temperature sensor right on the terminal. I would like to upgrade the terminal, but it appears this sensor must be right next to the battery.
Any suggestions on what I can do with it that doesn't look completely DIY? Or am I just stuck with the terminal, and I should just add a larger cable to the existing one?
Old Aug 29, 2023 | 06:03 PM
I'm not as familiar with the 2017 accord setup. How is that temperature sensor mounted to the bracket?
Are you having electrical/charging issues with the current alternator? Or did you replace the alternator with a higher output version?
SJ443
Nov 16, 2022 10:43 PM
The Toecutter
Jan 29, 2020 05:16 PM
kjkcjk
Jan 7, 2020 04:55 PM
peabody
Dec 10, 2016 12:14 PM
accordfan222
Aug 24, 2007 03:40 PM
