2018 Accord Climate Control Unit Issue
Old Feb 28, 2021 | 08:51 AM
danieltubb's Avatar
Default 2018 Accord Climate Control Unit Issue
Has anyone experienced an issue with the climate control unit not turning on? Also the ambient outside temp reading is not working in the instrument panel. My first assumption is a relay or fuse but I cannot find which ones are associated with the CC unit.
Old Feb 28, 2021 | 10:23 AM
Seanjordan20's Avatar
Is the car still under warranty? If so I would take it in for service. If not have you tried to reset it. Have you disconnected the battery for 15 mins and seen if that works? If your ambient temp sensor is not working then the climate control would be effected. Have you checked the connector to the sensor?
Old Feb 28, 2021 | 11:57 AM
danieltubb's Avatar
It is still under warranty. I disconnected the negative from the battery but for only like 5 minutes. The sensor connector is intact. I do not know how to reset it. If you know and can share the process, I would appreciate it.
Old Mar 1, 2021 | 05:57 PM
I would do the warranty thing. You paid for it...
I'm moving this to General Tech because it's not really an "internal engine" thread.
Old Mar 1, 2021 | 07:00 PM
The fuse to check would be under-dash Fuse No. B14 (10A).
Non Quixote
May 19, 2021 01:22 AM
Dblboinger
May 28, 2014 10:13 AM
Dave L
Oct 29, 2012 09:22 PM
dragonle87
Jun 10, 2009 06:59 PM
mikebrawn1
Mar 28, 2007 12:23 AM
