2018 Accord issues with key fobs not working
Old May 8, 2023 | 07:08 AM
ldesiano's Avatar
Default 2018 Accord issues with key fobs not working
My keyless entry stopped working. I replaced the batteries in both key fobs and that did not help. I can start the car with the key fobs but only if I press them to the start button. I went through the process of pressing the lock and unlock on both key fobs with the car on to try and re-register them. Red light on key fob turns on, then off, then back on again and stays on until I release the button, but that has not changed anything. It doesn't seem probable that both key fobs would be bad. Looking for some direction to figure out what is not working.
Old May 8, 2023 | 09:07 AM
Check under-hood Fuse No. A27 (10A) - back up fuse.
The back up fuse powers the key-less components, including the START button. If that fuse was blown, the car may not start if the key fob was not near the START button; but, could start when the key fob was near the START button.
Old May 8, 2023 | 09:37 AM
ldesiano's Avatar
Is that in the fuse box in the engine compartment or under the dash?
Old May 8, 2023 | 10:02 AM
Under-hood is engine compartment.
Old May 8, 2023 | 10:31 AM
ldesiano's Avatar
Getting closer. Fuse was missing. I was doing some testing the other day and must have pulled it out and dropped it.
Now the car recognizes the key fob but only to the point that it car knows it's in the car and it will start without having to put the key fob up against the start button. But the buttons on the key fob qare not functioning. Also, the seat position save buttons on the door don't respond either. Went back through the process of registering the key fob but that didn't help. Also have new battery in key fob.
Old May 9, 2023 | 08:37 AM
ldesiano's Avatar
Redbull, do you have any additional advice?
Old May 10, 2023 | 05:55 AM
ldesiano's Avatar
Default 2018 Honda Accord Key Fob Problem
I have 2 key fobs with new batteries in them, but having the same issue with both. My car will start when the key fobs are in the car without having to press them to the start button, but none of the buttons on the key fobs work, and the preset seat settings on the drivers door do not work either. I've gone through the process of clicking the lock and unlock buttons while the car is on, and the little red light comes on, but it doesn't seem to be registering with the car. Any thoughts?
Old May 10, 2023 | 09:19 AM
ldesiano's Avatar
Cool
Problem Solved. The problem I discussed was from yesterday. Today everything is working fine. Explain that one.
Brookearp
Feb 24, 2023 08:55 PM
Barbas210
Oct 14, 2019 10:27 AM
Todd Guzy
Jun 9, 2019 01:16 PM
baydude876346
Jan 15, 2019 08:41 AM
whiskeywarden
Feb 6, 2012 11:23 PM
