4 cylinder 99 Honda Accord Ex Timing issues
Old Feb 8, 2018 | 02:14 PM
masager13's Avatar
Unhappy 4 cylinder 99 Honda Accord Ex Timing issues
To give you a run down I had a blown head gasket. I attempted to start it and didnt have the distributor installed correctly and sheared off the key ways to the distributor. I was able to retrieve both and bought a new one. After replacing it the car will start, but is running rough. I am getting black smoke from the exhaust and idle seems to be off. When trying to rev up the engine it stalls and then jumps up back and forth. Once I let off of the gas it will stall completely. I checked to make sure cylinder 1 is at TDC, and all of my marks line up. When the car is at operating temp, using the timing light it the TDC mark is showing up right on or a little after. This is an improvement from it being about 20 degrees off from before. I disconnected the battery and pulled the ECU fuse to achieve that adjustment. I dont know what else to do. Any help would be appreciated.
Old Feb 9, 2018 | 09:37 AM
Check spark plug wire routing; 1-1, etc.
Old Feb 9, 2018 | 09:39 AM
masager13's Avatar
Thanks. I I have traced them out multiple times.
Old Feb 9, 2018 | 10:52 AM
Have you checked for codes?
Check fuel trims (LT and ST) for too high/low performance. Check fuel pressure for correct pressure.
Old Feb 9, 2018 | 11:01 AM
masager13's Avatar
No codes as of yet. I will check those next ThanksTh
knowsnothingaboutcars
Mar 16, 2017 09:23 AM
Chris Jameson
Feb 19, 2013 06:39 AM
STINKA621
Mar 9, 2009 07:53 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
