5th gear grind
Old Feb 21, 2012 | 09:27 AM
accord99's Avatar
Default 5th gear grind
On my 99frigging accord when shifting into 5thit gear it grinds the gears. If I pause a sec and slowly shift it doesn't do it all the time. 5th only. Changed fluid and all looked good. What is this problem?
Old Feb 21, 2012 | 09:30 AM
Probably the syncro, pretty costly to replace if you don't do it yourself(its inside the transmission). Would probably be cheaper to pick up a used tranny and swap that in. Or just live with the grind.
Old Feb 21, 2012 | 11:49 AM
Using Honda MTF? I've heard of people getting improvement by using that instead of other MTF. Also, Pennzoil Synchromesh (AKA GeneralMotors Synchromesh) might be even better.
Jet sitter
Mar 6, 2013 11:32 AM
fly68
Apr 6, 2009 06:52 PM
hondaman4000
Aug 7, 2008 11:55 PM
low_go_91
Apr 12, 2008 08:08 AM
