5th gen 5000RPM at idle!!
Old May 28, 2007 | 10:43 PM
dappa1's Avatar
Default 5th gen 5000RPM at idle!!
my 94 lx with a f22b vtec swap is idling at a crazy 5000 RPM.. when i start the car the idle just shoots up there.. this started happening after i swapped out the throttle body.. but i didnt change the gasket..could this be cuased by a bad throttle body gasket?? and btw i have a cel for o2 sensor, but i had that before the ilde problem. any idea what could cause this ??
Old May 29, 2007 | 12:44 AM
BlkCurrantKord's Avatar
Default RE: 5th gen 5000RPM at idle!!
Vacuum leak, get a new gasket.
Old May 29, 2007 | 01:06 AM
My idle has shot up very high whenever I do anything near the throttle body.
I would pull the backup fuse (7.5 amp) for 30 seconds, and the high idle returns to normal.
The 7.5 amp fuse is on the upper right hand corner of the fuse box in the engine and is labeled Radio and maybe ECU.
Old May 29, 2007 | 02:03 AM
dappa1's Avatar
ORIGINAL: BlkCurrantKord
i will try that
Old May 29, 2007 | 02:04 AM
dappa1's Avatar
ORIGINAL: PAhonda
tried this.. nothing changed
Elk Hunter
Oct 2, 2012 11:08 AM
coolcat
Nov 24, 2008 08:39 AM
Ponyboy
Jun 1, 2008 01:13 PM
kenneyd
May 1, 2008 11:28 PM
finch13
Apr 15, 2008 10:13 AM
