6th gen clutch pedal interchangeability? Need help
Old Jun 7, 2019 | 12:31 PM
01accordjason's Avatar
Default 6th gen clutch pedal interchangeability? Need help
Hello, I'm new so want to say hello first of all.. Secondly I'm having a problem, recently my 01 decided it didn't wanna go into gear not long after I felt a pop in my clutch pedal. Well I removed the pedal a week ago and found that the top part of pedal welds have snapped so I'm not getting enough pedal to disengage clutch. Anyways, I can't find another mt in my local junkyard but can find plenty of 96-00 civics (which I have a 98). It APPEARS that my 98 is very similar in how it mounts. Holes seem to match up. Without removing the one from my civic can anyone tell me FOR SURE if they are interchangeable or not? Thanks guys.
--below are pictures of where it broke, anyone ever seen this happen?? Normally brackets break, never seen this
one myself
Old Jun 7, 2019 | 07:30 PM
Go to a site like hondapartsnow.com and look up the oem part number for your car. Then open the same site and search by only the part number (no car information). That should list all vehicles that use the same honda part.
Old Jun 9, 2019 | 07:20 AM
Ok I'll try it
Old Jun 10, 2019 | 04:27 PM
Default Question answered
Well yesterday I went and got a clutch pedal out of a 98 Civic brought it home to match up with mine from my 01 Accord and the housing and pedal is a perfect match it set for one of the sensors that has the welded nut on the bottom. The one on the Civic has a smaller nut and sensor. So all I did was pull out the pedal from the Civic put it in my housing on my 01 Accord and installed it today with no problem. There for anybody that runs across this problem again can use a 96 to 2000 Honda Civic clutch pedal and use their Accord housing. If their housings bad you can use a Civic housing and drill out the hole a little bigger for the Accord sensor and weld a bigger nut to it.
grim_reaper
Feb 23, 2012 09:04 AM
coolcat
Nov 24, 2008 08:39 AM
Ponyboy
Jun 1, 2008 01:13 PM
finch13
Apr 15, 2008 10:13 AM
bigdog1428
Dec 19, 2006 09:07 AM
