6yr/90K mile service
Old Aug 23, 2007 | 04:49 PM
funaccord
Default 6yr/90K mile service
Hi All , I am a new member and need some help, called in couple of honda dealerships for getting a quote on 6yr/90Kmile service and got the quotes as $535 and $370 does this sound reasonable price ? below are the items included in the service ($370 charge)
Replace all Fluids/Filter (Brake fluid, Trans fluid, Coolant etc)
Rotate tires
Replace Oil/Filter
and does $140 for brake pad replacement sound right ?
thanks in advance
Old Aug 23, 2007 | 05:00 PM
00AccordLX5spd's Avatar
Registered User
Default RE: 6yr/90K mile service
$140 for a brake pad replacement is a huge rip off. You can do it yourself super easily with a jack, some jackstands, and basic hand tools (Honda OEM brake pads cost about $35 from hondaautomotiveparts.com). If that quote only includes those services you listed it is absolutely ridiculous. You can EASILY do all those yourself (brake fluid change would probably be the most challenging, but still not hard.) Go to AutoZone and buy yourself a Haynes manual for basic services like these.
Did the dealer not mention a newtiming belt, water pump, oil seals, and drive belts? Those need to be done at 104k (or every 7 years) on 1998-2002 Accords. Get a Honda Certified shop to do that one - it will probably run around $500 or so.
Old Aug 23, 2007 | 05:49 PM
deserthonda's Avatar
before i can give you a proper reply , i would need to know the model of the car v6 ,4cyl., at ,5 sp .. i am assuming it is a 2000-2001 ?? 6 yr?? also get a list of what they are going to do exactly ..
also if t-belt has not been done i would suggest that you do it as well
https://www.hondaaccordforum.com/ser...m_33323/tm.htm
as for the brake pads, you can get a set from honde for 50-60 dollars and replace them yourself, ,, there are write ups on the DIY section..
Old Aug 23, 2007 | 07:45 PM
funaccord
my bad forgot to mention it is a honda accord 2002 4 cyl, with 35k miles on it
Old Aug 24, 2007 | 04:08 AM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Aug 24, 2007 | 09:53 AM
Registered User
ORIGINAL: JerryM
My experience with dealerships is most will do good work, but you will pay $$$ for sure.
Igo toa local family owned Honda/Acura repair shop. They are honest and the price is very reasonable.
You might want to consider calling around your area for quotes.
Absolutely. I called around where I live and all the dealerships were asking about $100 more for a tbelt, h2o pump, drive belt change that the Honda Certified shop I got the job done at. Whip out your yellow pages and call around.
Only 35k miles!? That's nothing! I personally wouldn't get anything major done till I hit about 90k! No wonder the dealer didn't recommend a t-belt & water pump change!
Old Aug 24, 2007 | 10:32 AM
ORIGINAL: funaccord
have a shop just do the 30k service ,,,almost the same thing ,,
again get a list of all thet they are going to do , to justify the cost ,go to our DIY and see what it should take
sschnei
Jan 27, 2010 08:31 AM
jenefa
Nov 6, 2008 07:03 PM
accord4sroy
Jun 30, 2007 04:52 PM
dave118811
Nov 8, 2006 05:01 AM
nil
Oct 24, 2006 10:37 PM
