Ride unstable after 90K service
Old Jan 25, 2010 | 10:21 AM
sschnei's Avatar
Default Ride unstable after 90K service
OK, with 180K miles on my ’93 Accord I bring it in to the dealer for a 90K service. Pick it up the next day and driving home the ride feels really unstable. Body motion feels very stiff in the upward direction then the body pitches way down after a road divot. At times like it’s rocking severely from left to right to left. It was not like this when I brought it in for service, the ride quality was very good prior to the service work Any ideas what might be going on? I’ll be bringing it up later today to have the dealer check into this.
Old Jan 25, 2010 | 03:55 PM
If they did an alignment, they messed something up. I agree first thing is give the shop a chance to make it right.
Old Jan 25, 2010 | 04:24 PM
kris_loehr's Avatar
I would check the lug nuts to make sure they are tight. "stiff in the upward direction " makes me think of a bent control arm which could give you "the rocking severely from left to right to left" Strange things happen but the dealership will take care of it. When I had my 95 Accord towed in for the balance seal replaced my car drove like that. The wrecker driver tied down a rear control arm and bent it really bad.
Old Jan 25, 2010 | 04:29 PM
deserthonda's Avatar
most likely they rotated the tires and now ride is different ,but i would take it back and have then chk it out
Old Jan 25, 2010 | 10:18 PM
96FiveSpeed's Avatar
Too difficult to say online...could be plenty of things...let us know what they found out.Hope they fix the problem!
Old Jan 26, 2010 | 03:33 PM
mcnoople's Avatar
On a car that old it could be a shock that failed dueto lifting. There is a tsb for lifting a car and causing something internal in the shock to fail. I've never seen it and I believe it is supposed to be much more common in high mileage southern car due to summer temperatures affecting the components. I have seen strut mount bearing fail apart as soon as the weight of the car was no longer acting upon it.
They may have screwed up or it may have just been some bad luck for you and them. But they should have test drove the car before returning it.
Old Jan 27, 2010 | 08:31 AM
sschnei's Avatar
Thank you for the input! A return visit to the dealer found two front struts were locked up apparently from being left up on the lift overnight. I could not find anything on-line about locked up struts, so this was news to me. Dealer is working with me though … covering labor, rental car, and parts at a discount.
accordhybridowner
Oct 27, 2011 09:16 PM
accordhybridowner
Oct 25, 2011 06:36 PM
jenefa
Nov 6, 2008 07:03 PM
spool666
Apr 19, 2008 10:59 AM
funaccord
Aug 24, 2007 10:32 AM
