'85 (w/ carburator) dies once on startup every time
Old Sep 6, 2012 | 11:41 PM
jacksprat's Avatar
Default '85 (w/ carburator) dies once on startup every time
Hi All:
I inherited the car a few years ago and fixed it up some w/ a rebuilt head & new fuel pump & relay because it seemed too good to just toss out. It runs fine but the weird starting still eludes me. it used to die at stop signs too but I jerry-rigged a bypass on a vacuum solenoid that's supposed to boost the engine to overcome power drain by the AC, so that it's always on. Now once it warms up for a minute it usually runs ok, but it's a workaround and not a solution. gets about 23 mpg on back roads (the only kind we got here), & up to 31 on the freeway.
I kind of suspect that the problem is a vacuum pot attached to the choke, ok let me qualify that: That vacuum pot seems ok but somewhere there are valves that turn it on, such as the AC boost, & I suspect there are other conditions where it should engage too, like startup. Does anyone know where that valve is? other suggestions?
thanks
Old Sep 7, 2012 | 04:28 PM
Exclamation Hell Newbie...
Ya posted in the WRONG Forum Thread, I moved it to here.
Make sure you look and read before you post.
You should get and answer in this thread..
Old Sep 7, 2012 | 04:55 PM
jacksprat's Avatar
Default thanks
You've done me a great service. I shall remember this after the revolution.
even though you're smarmy, and territorial.
HashGobbler420
Jun 8, 2012 07:00 PM
meditativecruiser
Apr 14, 2011 08:09 PM
elfucer26
Jul 9, 2010 08:40 PM
mst1963
Oct 8, 2009 01:51 PM
DRJIV
Feb 10, 2007 12:11 AM
