86 accord dx 2 barrell carb.
Old Aug 26, 2006 | 02:36 AM
sukka68
Default 86 accord dx 2 barrell carb.
First let me say hello all i am new and would like some assistance with my car if i could please. My issue is that when i turn a corner and begin to accelerate my car when it gets above three grand will begin to buck to beat the band, when this happens i need only to turn of and back on the ignition switch a couple times and it goes away, can anyone give me some insight on this issue???
Old Aug 26, 2006 | 09:45 AM
Default RE: 86 accord dx 2 barrell carb.
Hello New Member...
Thank you for joining the forums of HAF!
When was the last time you changed your fuel filter please!
Old Aug 26, 2006 | 07:03 PM
lightshow's Avatar
sounds like more carb then electrical or ignition. clogged filter would do it. bad fuel pump, clogged jets, faulty accelerator pump
Old Aug 26, 2006 | 10:24 PM
sukka68
i have very recently rebuilt the carburetor and did a complete tune up (plugs wires cap rotor and also three cans of carb cleaner in the gas) and i also replaced the primary and scondary fuel filters. The only reason i thing it might be electrical is that when i turn off the ignition off twice it goes away for a while...any suggestions would be greatlt appreciated.. and thanx for the kind welcome :-)
Old Aug 27, 2006 | 06:01 PM
deserthonda's Avatar
ORIGINAL: sukka68
does this ONLY happen when you are turning ?? so after you turn the car off and restart it , you can turn a corner and will not have the problem ??
Old Aug 29, 2006 | 02:06 AM
sukka68
Yes happens more offen when turning and accelerating. If I turn and gently accelerate , it does not seem to do it as bad but if i get to or over three thousand RPMs it starts to buck badly. All I do is shut off the key with it still in gear and turn it right back on two or three times and it goes away till i turn again. I have been having a problem with the squirter hole for the accelerator pump getting clogged. When i rebuilt the carb. there was ALOT of junk in the bottom of the bowl I cleaned it out but when I had to pull the top of the carb. off to unclog the squirter it was full of trash again. I am thinking about draining the tank and flushing it out.???
THE CAR IS AN 1986 ACCORD DX 2.0 WITH TWO BARRELL CARBURETOR...THANX FOR THE HELP...
ohanahorse
Oct 12, 2009 02:35 PM
ohanahorse
Sep 16, 2009 12:37 PM
87DXACCORD
Jan 20, 2009 02:29 PM
Aerik
Mar 17, 2008 10:18 AM
p89
Aug 5, 2005 10:29 PM
