87 LX Hazard Flasher Problem
Old Jan 15, 2010 | 01:20 PM
ronlen's Avatar
Question 87 LX Hazard Flasher Problem
Both the hazard flasher and the turn signals abruptly stopped. I checked the bulbs and fuses (OK) and replaced the flasher relay (under dash/driver side).The turn signals work until you move the hazard switch to "on" then everything stops again. After awhile the turn signals begin working but not the hazard. Hit the hazard button and everything stops again. Is there a separate hazard relay (if so, where) or are they combined in one? Any idea what the problem is?
Ronlen
Old Jan 15, 2010 | 03:47 PM
My knowledge is based off of the 95 accord, so your 87 may be different. The online manuals thread in the DIY section has a spoon link I posted that has an 86-89 shop manual you can download.
The turn signal and hazard use the same relay in my car. It sounds like your problem is with the hazard switch on top of the steering column. You might want to clean out the electrical connection to see if that solves the problem before replacing.
Old Jan 15, 2010 | 03:49 PM
hondadude's Avatar
I don't have a schematic in front of me right now, however I think the problem is the contacts in the combo switch under the steering wheel.
mattjurek
May 14, 2015 09:38 AM
PeterFlorida
Feb 26, 2013 09:09 AM
hondaddy
Sep 17, 2010 05:25 PM
4DRBEATER
Mar 6, 2009 03:25 AM
johnny123
May 4, 2007 12:12 PM
