89 accord cruise control problem
Old Apr 3, 2011 | 09:07 AM
bnugen's Avatar
Default 89 accord cruise control problem
when i turn the master switch on the dash on for the cruise the cruise light doesnt come on and when i get to speed and hit the set button the cruise light flashes on for about 2-3 seconds and goes back off and the cruise does not work. i checked the fuses and everything is ok. any ideas?
Old Apr 3, 2011 | 09:19 AM
The dash switch cruise-on light is directly connected to ground and power is supplied through the switch (at least on 90 Accord), so light should come on if switch is closing. If not, bad switch, open light, or open fuse.
Did you check the under-dash fuse? It supplies power to the main switch.
Make sure you brake lights are not stuck On, as this will disable cruise also.
Check Online Manuals sticky post in DIY forum for links to download manual for your car. I believe there is one from Hondahookup.com that is mislabled as 89 Accord Secan. This should have all the diagnostics to find your problem.
Old Apr 3, 2011 | 10:52 AM
I'd also check for codes. The ECU is under the dirvers seat. Key on, count the flashes.
Old Apr 3, 2011 | 09:09 PM
bnugen's Avatar
i did check the under dash fuse and it is just fine. ill check the power and ground if those check ok ill try putting a toggle switch in to see if that fixes it. if so, off to get a new switch. and the brake lights work properly also
Old Apr 4, 2011 | 06:39 PM
The reason I asked about the codes, a bad VSS can cause the cruise not to work. Also if the brake light switch is not properly adjusted then that could cause the same issue. Yes a mis-adjusted switch will allow the brake lights to work but not the cruise.
blan
Jan 31, 2012 10:08 AM
apacha
Aug 3, 2011 09:01 PM
manuel831
Mar 12, 2011 07:56 PM
Dagonus
Mar 1, 2011 11:24 AM
franklin
Dec 25, 2007 12:49 PM
