89 accord distributor part number?
Old Aug 16, 2007 | 10:27 PM
88accord's Avatar
Default 89 accord distributor part number?
I have a 1989 Accord LXi (fuel injected) with an automatic. The car is hard to start, and sometimes does not start at all. We hooked the distributor up to a scope, and its output was all over the place. A mechanic we talked to said it was a bad distributor module and that this is a common problem with these distributors as they age. Anyone have experience with this? I cannot find the part number for the distributor either. Anyone know what it is? Also, anyone know where to get a good distributor for these cars? They seem a little hard to come by...
Old Aug 16, 2007 | 10:37 PM
deserthonda's Avatar
Default RE: 89 accord distributor part number?
before you replace anything you should diagnose if indeed is lack of spark when car does not start ,could be the ignitor ,, but , it almost sounds like your typical main relay problem,,
when car does not start, spray some carb cleaner in the throttle body see if it starts ,, if it does, i would look at the main relay first ,,,
there are some write ups on our DIY section
Old Sep 2, 2007 | 09:27 AM
88accord's Avatar
Just FYI, it was the main relay. I read up on the article in the DIY forum, and every diagnostic pointed to the main relay. Saved $300 by replacing the relay instead of the distributor (mechanic said distributor was bad). Thanks again.
TeaQue
May 22, 2013 11:49 AM
tazman2009
Dec 26, 2012 07:52 AM
dodge22racing
Dec 15, 2012 05:23 PM
nicolaselias
Mar 24, 2008 12:12 PM
Mattsrt
Mar 11, 2007 11:08 AM
