89 accord elec door lock
Old Apr 26, 2010 | 06:52 PM
czrandy's Avatar
Default 89 accord elec door lock
the elec door lock switch only locks the doors wont unlock. I took the switch loose from the door and eyeballed it it seems ok I also used a piece of wire to jump the terminals on the back and the lock cycle is working but the unlock dosent so i think the trouble is before the switch this may be a dumb question but could there be a seperate fuse for lock and unlock? what is my next thing to do?
Old Apr 29, 2010 | 09:15 AM
hondadude's Avatar
Sounds like you need an old grey haired Geezer to help you with that classic car.
Under the passenger front seat there are 2 or 3 control units; the one in the middle is the power door lock controller.
Unplug it, remove it, carefully pry on the edges and you can slide the circuit board out. Then look very carefully for cracked solder joints.
Duner
Nov 7, 2013 05:37 PM
Doublel
Mar 11, 2013 07:57 AM
leeroy82
Sep 10, 2010 04:31 PM
joe88accord
Sep 4, 2010 07:55 PM
atorifan
Aug 13, 2010 02:33 AM
