89 high nox at low speed test
Old May 3, 2014 | 07:45 PM
Donald Jones's Avatar
Default 89 high nox at low speed test
getting 1000 nox at 15 mph 400 range at 25 mph. egr seems to work with egr test using another vacuum source almost stalled engine. can't find vac leak timing ok. help
no engine codes, but probably unrelated I do have that pesky main relay intermittent no start problem.
Old May 4, 2014 | 07:27 AM
There can be more than just an egr issue......lean because of X.
Is there a vac leak somewhere.
Is this a carb or FI?
Old May 4, 2014 | 10:46 PM
FI, vac seem strong rpms go up when I disconnect one of the main lines could there not be vac getting to egr via the switch and diaphram (the vacuum control box)
Old May 6, 2014 | 09:26 PM
To test the theory on the egr, you'll have to "tee into" the vac line to the egr and see what you are getting when driving the car.
I think the LXi's had a lift sensor on the egr? So if you were getting a low/high lift at the wrong time I would have thought you'd get a CEL for the egr system.
How old are the two O2 sensors?
Old May 7, 2014 | 02:22 AM
holmesnmanny's Avatar
normally I've found when you pass the 25 nox but not the 15 nox test this is either the egr is clogged up or the cat is bad
Since it's cheaper, though not easier, to clean out the egr valve and ports it might be best to do that first and see if it passes, and if not then I would replace the cat, especially if it's never been changed out.
I've actually never seen a howto on a 3rd gen accord so hopefully poorman will teach me something new in this thread.
Old May 10, 2014 | 05:35 PM
original 02 sensors
brian1012
May 10, 2012 02:21 PM
irhunter
Mar 23, 2011 04:49 PM
jtkj
Nov 21, 2009 09:00 AM
Rusty
Jul 29, 2009 12:30 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
