90 Accord LX Starting Problem
Old Dec 13, 2008 | 04:33 PM
Default RE: 90 Accord LX Starting Problem
Its normal for some voltage drop. But that drop should occur over the length of the wiring, for example. You dont want to see a drop across something like a clamp.
Make sure you check the difference between the wire clamp vs the wire itself. Maybe corrosion where the cable end is crimped onto the cable itself??
Old Dec 20, 2008 | 07:53 PM
hansw3's Avatar
Default FIXED! RE: 90 Accord LX Starting Problem
Bad battery was the problem. I had swapped out the battery with a 3.5 yr old one that was working fine in my jeep this summer, therefore I thought the battery wasn't the problem. That turned out to be bad too. One of the cells was froze solid when I brought it into autozone for compuer load testing. UNfortunately I did't do this until pulling battery cables and swapping them and messing around for more time than I'd care to admit. When I put the voltmeter on the battery and had a buddy crank over the engine she would drop down to 5 volts. Also, a month ago when I was bench testing the original starter I pulled out I was dupped because I was testing it with the original bad battery. The terminal to cable crimp connection was bad too.
The cold weather exacerbating the problem makes sense now...
Next time I will be going to Autozone for battery testing sooner than later!!! I think the battery was bad since I bought the car over a year ago.
Old Dec 21, 2008 | 04:09 PM
Default RE: FIXED! RE: 90 Accord LX Starting Problem
Thanks for telling us the end of the story. Often we never find out if things work out or not.
Yamasaki
Nov 5, 2011 09:19 AM
quack31
Feb 5, 2007 05:07 AM
babylon888
Feb 16, 2006 02:08 PM
cyurgeles
Jan 21, 2006 10:36 AM
rev2ninetyper
Nov 14, 2005 04:06 PM
