'90 automatic won't shift past 2nd
Old Feb 9, 2008 | 05:55 AM
pfrathjr
Default '90 automatic won't shift past 2nd
The sport shift light is lit constantly. I have to shift manually from first to second, and the transmission won't go beyond second. This condition was present for a few weeks, and then seemed to spontaneously "fix itself". Now it is happening again. Is this a relatively simple electronic problem? Any help appreciated!
Old Feb 9, 2008 | 08:12 AM
Default RE: '90 automatic won't shift past 2nd
This is a symptom of damaged Trans Control Unit. There are two TSB's on this, TSB 017 and TSB 90-039.
Diagnostics
1)Step on brake pedal w/ keyswitch ON. The interlock control unit may stop buzzing or clicking.
2)Reset the AT Control Unit by pulling Fuse 24 in the underhood fuse box. The S light remains off and trans shifts normally.
3) Removing fuse 24 does not clear the AT Control Unit.
Any of above would indicate you have this problem. The AT control unit board may show a damaged (burnt) component.
Try a search of forum for Trans or Transmission problems.
A rebuilt or used TCU should fix this problem, if it's confirmed to be the fault.
Old Feb 10, 2008 | 02:33 PM
pfrathjr
Thanks! I pulled the fuse and the TCU reset itself.
Old Feb 10, 2008 | 05:51 PM
What happened? Shifting normally & S light off? I would wait to see if S-light comes on again,...likely.
If yes, then a replacement TCU is fix.
swingkid50
May 20, 2012 09:29 PM
ghostpilot
Aug 6, 2011 08:42 AM
Mdschmidt
Oct 24, 2010 10:34 PM
sofireguy
Jul 7, 2009 01:32 PM
hondadad69
Jul 26, 2007 05:17 PM
