90 Honda randomly not starting...please help
Old Aug 8, 2007 | 07:52 PM
sportsaddict227
Default 90 Honda randomly not starting...please help
Hello! I am in need of some help.[sm=helpout.gif] I have a 1990 Honda Accord with an automatic transmission. It only has 55,000 original miles on it. My S light keeps flashing randomly and when it does this my car will not start. There is absolutely no pattern to this but it does appear to be happening more often. Sometimes it will start back up within 10 minutes and sometimes I get stranded for 3-6 hours somewhere. When I checked the codes (if I did it right) they were related to sensors and something about no signal to ECU. The car runs excellent when it is running. If there is anyway you can help I would appreciate it. I was told to add the actual codes that came up when I checked them so I am going to do that. The codes were oxygen sensor, map sensor, ckp sensor,idle mixture adj sensor,and angle sensor. I am clueless when it comes to cars and my husband is not much better so please help me. I am tired of getting stuck in 100 plus degree heat with my daughters.[sm=smiley13.gif]It is to the point that I am afraid to turn my car off for fear it will not start. Any help is very much appreciated. [sm=feedback.gif] Thanks!
Heather
Old Aug 9, 2007 | 12:15 PM
Default RE: 1990 honda accord question
You need to post the code numbers you extracted.
Failure to start after stopping, particularly if car is left in open sun can be due to a failing Main Fuel Relay (MFR). Do a search on main fuel relay for lot's of advice. Look upder DIY section for further guidance.
Old Aug 10, 2007 | 09:49 PM
sportsaddict227
Thanks for your advice! I will definitely check that out.
sarcastiq
Mar 2, 2013 05:15 PM
heatherfly
Oct 27, 2012 08:35 PM
Opinion8ed
Oct 19, 2011 01:00 AM
BertMan
Aug 10, 2007 09:57 AM
