91 Accord AC Quit
Fuses seem fine. Where do I start? What do I look for? Anything is appreciated. Still blows air, heat works, just no AC. It quit quickly, so I don't think it just needs charged.
Look to see if the clutch plate spins with the compressor pulley when you have the engine running and the a/c turned on. In the video below, the compressor is shown around 14minutes with the plate not moving. At about 15 minutes, the compressor turns on, and you can see the clutch plate spinning.
The compressor on your car is on the driver's side of the engine towards the bottom of the car. The belt that drives your alternator drives the compressor. You may need a flashlight to see it. Be careful not to get anything caught in the moving belts.
indianbullet
Jul 8, 2012 09:48 PM
