91 Accord Brake Bleeding Question
Old Dec 9, 2009 | 08:21 PM
crack3d's Avatar
Default 91 Accord Brake Bleeding Question
Hey all! I just replaced my brakes and I think i got air in the brake line. I was wondering if anyone knew the bleeding sequence for a 91 accord lx (no ABS). Any help is much appreciated!
Old Dec 9, 2009 | 08:48 PM
kris_loehr's Avatar
The bleeding sequence is normally in order of the furthest from the master cylinder which be passenger rear first and driver’s side front last. If you didn’t open the hydraulic system when doing the brake job then you will not have air in the system from the job. You didn’t post if you did rear shoes or front pads. If you did rear shoes you need to adjust the shoes with the self adjuster.
Old Dec 9, 2009 | 09:03 PM
crack3d's Avatar
Thanks for your reply. I put on rear shoes, the brakes worked fine before i put the shoes on, my brake pedal goes to the floor and that's why I suspect its air in the line. I'll check the adjuster and see. If you have anymore information feel free to share
Old Dec 9, 2009 | 09:32 PM
kris_loehr's Avatar
I am glad to help. The self adjusters are suppose adjust if needed every time you back up and hit the brakes but they don’t work well. You can have the drums on to adjust and there should be a rubber plug at the top of the backing plate you remove and click the adjuster. I just did my 95 Accord and it was not easy even with a brake spoon. The other method is adjusting the shoes drum off and keeps trial fitting the drum. I run them tighter than most with just the drum on being a little hard to turn.
Louay
Mar 15, 2012 05:09 PM
jedavisiv
Jun 11, 2009 08:23 AM
vramsaran
Feb 26, 2008 08:24 PM
nmikmik
Dec 1, 2007 11:14 AM
BlueByYou
Oct 8, 2006 01:43 AM
