91 Accord A/c just stopped working
Old Nov 19, 2005 | 04:43 PM
jayallen40
Default 91 Accord A/c just stopped working
The a/c on my 91 accord just stopped working all of a sudden. The compresor is not comming on I have checked the fuse in the fuse box in the car it is ok. I think I had a slow leak. Is it possible the freon gotto low so the compressor will not kick in?
Old Dec 4, 2005 | 10:46 PM
deserthonda's Avatar
Default RE: 91 Accord A/c just stopped working
if u are very low or no freon at all a/c compressor will not engage.......jump the high pressure switch at the rec drier ..if compr comes on most likely u are low on freon,,,,,,, another test ,, remove the recharge cap from the high pressure ( discharge hose ) hose, stick a small screrwdriver on the valve to depress it and see if freon comes out with a lot of pressure ,if hardly anything coming out recharge a/c , put a/c dye and chk for leaks..
19962door
May 7, 2012 12:43 PM
foxylady23
May 19, 2009 01:13 PM
dbennett3
Aug 11, 2008 11:49 PM
88COMMUTER
May 26, 2005 10:03 PM
