91 Accord dash light problem
Old Feb 11, 2011 | 10:44 PM
ryandavis33's Avatar
Question 91 Accord dash light problem
Hello,
My 91 Accord Auto 2.2 L is having some dash light problems.
Please see pictures for more detail
I have to hit the top of the dash multiple times to get the lights shown in picture 2 to turn on(the overhead dash lights)
The 3rd picture is what the dash looks like when i shine a flash light on it for refrence
The 4th picture is usually where i hit it
btw it has over 300,000 miles on it
Please please help
I really do hope it is a fuse
Thanks
Attached Thumbnails 91 Accord dash light problem-img00040-20110211-2022.jpg   91 Accord dash light problem-img00042-20110211-2026.jpg   91 Accord dash light problem-img00043-20110211-2028.jpg   91 Accord dash light problem-img00041-20110211-2023.jpg
Old Feb 11, 2011 | 11:06 PM
It is probably not a blown fuse if you can get the bulbs to turn on when you hit the dash.
I would test the dash brightness controller.
See the pdf at this site:
media.honda.co.uk/car/owner/media/manuals/accordManual/400/16-187.pdf
Old Feb 11, 2011 | 11:08 PM
The brightness works fine...i think it might be a short how can i fix this?
Old Feb 11, 2011 | 11:16 PM
A bulb needs voltage and ground. Doing the input tests will help determine if the problem is due to missing voltage or missing ground part of the circuit.
It is much quicker compared to removing cluster to test.
Old Feb 11, 2011 | 11:21 PM
ok got that
how do i do the test? I can see the diagram but what tool do i use and how?
Old Feb 11, 2011 | 11:31 PM
You can use a volt meter. The light switch should be turned on when doing this test. The key may or may not need to be turned to the II position.
1. There should be zero resistance (closed circuit) between the blk wire and ground. Any bare metal inside the car will work. Look under the dash.
2. There should be 12V between the red/blk wire and ground.
3. Use a piece of wire to connect the red wire to ground (use a piece of wire to connect #3 red pin to #1 black pin). See if the lights turn on.
Old Feb 12, 2011 | 12:14 AM
i think i understand...would there be and specific instructions on how to test connections?
thanks for all you help
Old Feb 12, 2011 | 12:39 AM
I'm not sure what you mean. Do you know how to test for voltage and ground using a multimeter?
Old Feb 12, 2011 | 12:47 AM
yes please...im a noob
Old Feb 12, 2011 | 12:52 AM
btw if i connect the red pin to the black the wire im using heats up and nothing turns on
if i connect black to red/black the lights light up but still not overhead lights like in picture 2
i still think it might be a short up in the dash...any suggestions?
