91 Accord Detonation Issue
Old Dec 9, 2010 | 04:19 PM
carl2782's Avatar
Default 91 Accord Detonation Issue
Hi Brains Trust,
My '91 2 door EX is detonating (hope that's the correct term, I'm Australian) quite badly when the engine is cold/under load. I had a mechanic check the timing recently, and I've also tried adjusting the timing a little by ear and it still does it. Just wanting some suggestions for what it might be? Spark plugs?
Thanks!
Carl
Old Dec 9, 2010 | 05:21 PM
I would definitely take care of the maintenance items first. When were the spark plugs, distributor cap, distributor rotor, and air filter last changed?
Old Dec 9, 2010 | 06:45 PM
Unusual for this engine to have detonation.
Reasons for detonation; timing advanced too much, combustion deposits, wrong spark plugs, lack of exhaust gas diliution (should not be a factor w/ a cold engine, only fully warmed), compression too high (special pistons or heads),
Are you sure the noise is detonation? A rattling clatter could arise from valves, but not quite the same noise.
tzoromski1
Oct 4, 2012 10:24 PM
Cubeman
Jul 23, 2012 12:40 PM
zZHellBlazerZz
Jun 15, 2011 10:12 AM
art vandelay
Aug 2, 2010 09:29 AM
partschanga
Mar 16, 2010 12:08 PM
