91 accord eld code
Old Dec 12, 2009 | 02:36 AM
RAWISCHUY
Default 91 accord eld code
going on my 3rd honda accord. never had problems till now. 91 accord turns on with low idle once she's warmed up idle picks up to about 1200rpms. drive good but after about 30 mins of drive she starts stalling and turns off . i got 2 codes. one is code 20 which is the eld. not sure what that is . the other is the o2 sensor. check engine light turns off at high idle {5-6000 rpms} when idle drops down the check engine llight turns back on.
Old Dec 12, 2009 | 03:16 PM
ELD = electric load detector
I think this is part of the engine bay fuse box.
Check the wiring at the O2 sensor connector.
I posted a link to a 91 shop manual in the online manuals thread in the DIY section. The fuel/emissions chapter has the engine codes listed and references to the page numbers of the troubleshooting procedures.
Old Dec 12, 2009 | 11:06 PM
RAWISCHUY
what causes the eld to go off. is it a bad distributor or is it my fuse box. why does my check engine light go off at high idle.
Old Dec 13, 2009 | 03:18 AM
I looked at the list of codes for the 91 accord, and there is no code 20. On my 95 there is a code 20 for the ELD.
You should recheck the code(s) and post both codes on here. You may be misreading them. You can either count the flashes on the LED or short the service connector behind the passenger side kick panel and count the actual check engine light flashes after you turn the key to the II position.
A long blink =10, short=1
Old Dec 14, 2009 | 12:43 AM
RAWISCHUY
double checked and its a code 20. the other code is 43 which is the o2 sensor. im concerned about the eld (code 20).
M-train
Sep 13, 2014 07:49 PM
d-day
Dec 14, 2013 10:58 PM
jlemberg
Dec 1, 2012 01:16 PM
pouncer11
May 16, 2012 08:21 PM
Queen eiko
Jan 24, 2010 12:09 AM
