91 accord ex problems
ok so i have a 91 ex 2 door 5 speed for sum odd reason today it did not want to idle. i was doing 68 mph and let off the gas for a min and it stald out on me had to pop the clutch just to fire it up. after sitting for 5 hours it ran ok for bout 20 min then started doing it again. now i have to push it to get it to start. tested the starter and tested fine in the test can sumone help me out need to get this fixed this is my daily driver.
when its not starting it will just crank crank and crank and yea lights work fine and after i let it sit for awhile it would crank for about 30 seconds then it would fire up and no my check engine light is not on after it stalls out on me i have to pop the clutch to start it and then it wont idle i just got this car three weeks ago and it ran fine till yesterday
Listen for the fuel pump to turn on for about two seconds when you first turn the key to the II position. It turns on during the clicks from the main fuel relay. It is a faint whirling/buzzing sound from the back seat area.
