Sponsored by:
Sponsored by:
91 accord ex problems
Old 08-31-2009, 06:51 PM
91accord091's Avatar
Default 91 accord ex problems
ok so i have a 91 ex 2 door 5 speed for sum odd reason today it did not want to idle. i was doing 68 mph and let off the gas for a min and it stald out on me had to pop the clutch just to fire it up. after sitting for 5 hours it ran ok for bout 20 min then started doing it again. now i have to push it to get it to start. tested the starter and tested fine in the test can sumone help me out need to get this fixed this is my daily driver.
Old 08-31-2009, 07:56 PM
What is happening when it is not starting?
Does the starter turn the engine? Are your dash lights coming on normally? Is the check engine light on when driving?
Old 09-01-2009, 05:19 PM
when its not starting it will just crank crank and crank and yea lights work fine and after i let it sit for awhile it would crank for about 30 seconds then it would fire up and no my check engine light is not on after it stalls out on me i have to pop the clutch to start it and then it wont idle i just got this car three weeks ago and it ran fine till yesterday
Old 09-01-2009, 06:00 PM
Listen for the fuel pump to turn on for about two seconds when you first turn the key to the II position. It turns on during the clicks from the main fuel relay. It is a faint whirling/buzzing sound from the back seat area.
Old 09-01-2009, 06:42 PM
i hear it kick on it sounds good no humming or anything else could i try to run dry gas through it cuz it didnt do it till i put gas in it
Old 09-01-2009, 07:47 PM
I'm confused from your last post. Do you hear the fuel pump turn on?
Old 09-02-2009, 04:45 PM
yea a tech at the local honda dealership told me since it has sat for awhile check the fuel filter and replace it. would this help me out
KimberlyC
04-16-2006 11:51 AM
Quick Reply: 91 accord ex problems
