91 Accord EX A/T Idle Surge of Unknown Origin - Help!
Old Mar 23, 2025 | 01:16 PM
  #71
chubkins's Avatar
Bad news. I went through the trouble of replacing the intake manifold gaskets and the surge is still present. If you didn't see before, I also replaced the throttle body gasket and cleaned the throttle body. O2 sensor also replaced.
Same issue. Surge from 1100-1500 when warm and perfect idle at 750 when IACV unplugged.
Old Mar 23, 2025 | 01:35 PM
  #72
chubkins's Avatar
I see some people have issues with aftermarket IACV's, and I think I have one on there. Looks new though.
- Tried something else, though: blocked off boost valve with aluminum plate. No difference in idle behavior.
Debating buying a new ECU.
Old Apr 3, 2025 | 12:18 PM
  #73
chubkins's Avatar
- Contacted old owner, said he replaced IACV and has the same problem.
- Replaced ECU. Idle hunted for a bit but resumed symptoms.
I noticed something though. On the low end of the surge (from ~1400 to 1100, so on the 1100 side) it feels like the car is misfiring/idling rough, and the car lets in more air to compensate. Could this be a fueling issue?
Should I check my fuel pressure?
This issue is a nightmare.
Old Apr 14, 2025 | 05:59 PM
  #74
chubkins's Avatar
Fuel pressure test says about 20PSI engine off car off.
Replaced fuel pressure regulator, same issue.
Maybe stuck open injector???????? Will measure today and report back.
Edit: All injectors show 2.0 Ohms at rest
TheOniGhostKing
May 14, 2025 10:44 AM
Joseph_accord
Oct 28, 2013 10:53 AM
jfidelh
Aug 30, 2011 07:24 AM
Doc_G
Dec 14, 2010 06:39 PM
gsrgofass
Dec 14, 2006 10:43 AM
