91 accord f22a4 stall
Old Apr 7, 2015 | 05:33 AM
Turtlehead's Avatar
I have heard of people mistakenly swapping the MAP and TPS connectors. Forgot all about that.
Old Apr 7, 2015 | 05:49 PM
Just me but you can make the car stall out and not re-start.....letting it run to op temp.
SO when you do this can you test for a good blue spark at the plugs and then also test for fuel?
The tps and map "switch" would happen with the car cold or warm.
Old Apr 7, 2015 | 07:11 PM
burd66's Avatar
Head was milled all gaskets and seals replaced as well as head bolts.
Put new fpr on today plugs fouled got no fire. Replacing plugs tomorrow for another try. Will keep updated.
Old Apr 9, 2015 | 02:22 PM
burd66's Avatar
Replaced plugs and fpr now car won't fire up cranks but no fire
Old Apr 9, 2015 | 05:04 PM
You keep changing parts, but do not try to diagnose the problem. See my suggestions above.
Make sure you didn't switch the fuel return line with supply line when you reconnected the fuel system.
Pondo
Apr 7, 2012 02:19 PM
mikepolo
Nov 27, 2011 05:38 PM
hmd810
Mar 18, 2009 08:35 AM
eband00
Dec 29, 2008 01:55 PM
Gastongo
Feb 25, 2008 05:03 PM
