91 Accord HELP!!!!!
Old Sep 17, 2011 | 06:40 AM
Any intake air leak can cause idle cycling.
Check all vacuum lines and vacuum supply ports for leaks. Check PCV valve/hose for faults. Check vacuum brake booster line. If all checks find nothing, check for intake manifold leaks by spraying throttle body cleaner while listening for a change in idle speed/sound.
Old Sep 17, 2011 | 03:22 PM
NONYAMT's Avatar
SIGH...Unfreekin believable!If there was one counterman in this town who knew half of what you guys have forgotten I could have fixed this thing last year!Everything seems to working as it should now,idle seems a little low but it was prob screwed up since I bought it so who knows.THANX GUYS!
Old Sep 17, 2011 | 03:33 PM
Well it sounds like you got something figured out,,,,I hope.
Old Sep 17, 2011 | 06:34 PM
How did you fix it? Where is the idle at now?
Old Sep 18, 2011 | 10:02 AM
NONYAMT's Avatar
Opened it up and the valve was just sitting in there,screwed it down and it fixed the "hunting" idle issue,idles at about 900 when warm. Thanx Again!
Old Sep 18, 2011 | 06:33 PM
NONYAMT's Avatar
Drove it 100 miles today,idle seems really low after a while,maybe 600 rpm,is that low?
Old Sep 18, 2011 | 06:43 PM
  #17
I don't have the specs. for the 4th generation Accords (i.e.,1990-1993); but, some of the 5th generation Accords idle should be 550 (+ or - 50) rpm; so, that sounds about right. The 4th and 5th gen Accord 4 cylinders engines were relatively similar.
Old Sep 18, 2011 | 08:03 PM
  #18
bigpat's Avatar
Almost A Senior Member
My 1993 idles in gear at 600 rpm when warmed up. In park, it idles at about 750 to 800 rpm. I thought that was a bit low, but the service mgr at Honda says it is correct for the car. I think there is a tune up spec plate on the inside of the hood...That might also list the proper idle specs. Personally, I would prefer to have it idle a bit higher...Maybe 750 rpm in gear...to lessen vibration in the steering wheel at idle.
Old Sep 19, 2011 | 12:41 AM
  #19
The 5th gen accords should idle at 750the rpm. Look at the sticker under your hood to see the proper idle.
On my 95, the scale on the tach didn't have a mark 250 rpm. So the marks were 0, 500, 750, 1000 rpm..... you might be at 700 rpm now
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
