91 accord lx goes into limp mode when car is warm
Old Aug 3, 2013 | 07:34 PM
  #21
When you jumped the leads to thermoswitch A, did only the radiator fan (passenger side) fan turn on? Or did the condenser fan turn on too?
Old Aug 3, 2013 | 09:25 PM
  #22
spear's Avatar
Just the radiator fan. And in case I've got them mixed up, the one closest to to the battery or right hand/passenger side of the car.
Old Aug 4, 2013 | 08:36 AM
  #23
Put 12v to the cond fan (left drivers side) motor - does it spin?
Old Aug 4, 2013 | 10:27 AM
  #24
spear's Avatar
Yes, the cond fan works. I kind of hijacked my own post, back one page is a list of the stuff I've done to this point in case you havent' seen it.
Thanks everyone.
Old Aug 4, 2013 | 05:25 PM
  #25
The ECU code 6 means the engine coolant temperature sensor or the wiring is not sending a reading to the engine computer. Or the reading is way out of range. This reading is used to adjust the air/fuel ratio and that is it.
The gauge in the car tells you the coolant temperature. What really controls the coolant temperature when the engine is running is the thermostat and the coolant temperature switch A. The thermostat closes to heat the coolant. Temperature switch A turns on the fans to cool the coolant.
If the gauge in the dash has the normal reading, then your cooling system is ok. I have never been able to see coolant flow from the radiator on my car.
To me, this sounds like a problem with the ECU or the TCU.
Old Aug 4, 2013 | 06:47 PM
  #26
spear's Avatar
Thanks PAhonda. That's helpful
Is trouble shooting the ECU or TCU doable for a home mechanic or is an ECU test harness like I see in the manual I downloaded kind of necessary?
Old Aug 4, 2013 | 06:59 PM
  #27
I think that you can do the tests without the test harness. Some tests you can do on the unplugged wire harness, and some tests you will have to back-probe the connector.
Make sure that none of the pins are loose. Especially the wires/pins that deal with the ECT sensor while you are in there.
Old Aug 4, 2013 | 08:00 PM
  #28
spear's Avatar
Thanks again, I'll re-post when I get somewhere.
imsohungover
Mar 29, 2025 02:27 PM
Idle4evR
Jan 14, 2012 05:33 PM
sitedude
Oct 22, 2011 02:07 PM
thumper44
Sep 22, 2010 05:02 PM
ronjr8102
Aug 31, 2010 07:05 PM
