91 accord no start/no spark?
Old Sep 10, 2009 | 10:14 AM
deserthonda's Avatar
you have checked the t-belt make sure it is not broken,,,,,,,,,,,have you tested the coil //
Old Sep 10, 2009 | 12:56 PM
killabeezyb
Tbelt is good,timing is good. Isn't the coil internal in dizzy
Old Sep 10, 2009 | 01:49 PM
On the EX the coil is under the distributor cap. The LX/DX has an external coil.
Old Sep 10, 2009 | 01:52 PM
doubled's Avatar
I had the same thing happen to my 91 , just shut down, here is a link to my thread, I origanally thought it was the fuel pump, but it turned out to the distributer. In the forum there is an explanation on how to test the two components in your dist, you can take them to autozone and check them befoer you purchase the wrong thing. My parts checked out good, so the only thing left to replace was the dist itself. Fired right up. When I orig posted that I had a bad fuelpump, because the day I went to chk everything out, it was hot and the windows were up. Turns out that these years have a prob with the fuelpump main relay (the solder on the circuit board cracks) and when it gets so hot inside the car, it expands and the car wont start. If its cool inside the car, it will start. That day I took the plug out of the fuel rail , turned on the key, and no gas (thats why I thought it was the fuel pump) So I would start with the dist. If you later have a prob with the car not starting when its hot, resolder the connections in the relay. in the meantime I will try to track that info down and add a link for it as well.
https://www.hondaaccordforum.com/for...hlight=doubled
Old Sep 10, 2009 | 03:30 PM
killabeezyb
mine is a lx and im 99.9% positive the coil is internal in dizzy, ive got a brand new dizzy complete and 2 junk yard dizzys, same problem, no spark. code 8 tdc sensor, any other ideas?
Old Sep 16, 2009 | 10:02 AM
killabeezyb
wiring is good btwn dizzy and ecu, power and ground at dizzy any suggestions
Tony1M
Nov 6, 2023 08:29 PM
sirtwist2
Sep 24, 2012 01:36 AM
SeanAccord
May 18, 2010 08:24 PM
thesameguy
Oct 5, 2009 09:39 AM
artman
Sep 14, 2009 08:46 AM
