91 Accord.....Should I Buy?
Old Jan 29, 2007 | 12:45 AM
GOH10 Runner's Avatar
Default 91 Accord.....Should I Buy?
Hey, I am new here and looking into buying a cheap reliable second car, I am looking at a 91 Accord EX coupe, 5speed, it has 200k miles on it, seems to be in good shape, no usual rust but I am wondering is there anything I should look at as some problem sport beyond the typical rust on the rear quarters and CV boots? Also anyone have any good experiences with this year and model? Pic below of the car
[IMG]local://upfiles/7838/ECE786FFE2F548F3BD4633FB34881228.jpg[/IMG]
Old Jan 29, 2007 | 01:16 AM
hondadude's Avatar
Default RE: 91 Accord.....Should I Buy?
That engine has a very good reputation; you might want to check with the seller about the Timing Belt, to find out if it is really old or just been changed.
Old Jan 29, 2007 | 04:55 PM
MALSR's Avatar
Pull out each plug wire from the valve cover and inspect them for oil. This is usually not too much of a concern but you could get the price down further if you find this.
Old Jan 29, 2007 | 05:09 PM
ArcticHonda's Avatar
With engine cold start up the car and then put gear selector in neutral right away. Notice if there is any erratic idle like the rpm revving up and then falling rapidly.
Old Jan 29, 2007 | 05:16 PM
ORIGINAL: ArcticHonda
What causes taht revving and falling idle, i had a friend whos 93 did that and they never knew what it was.?
Old Jan 29, 2007 | 06:43 PM
Itd usually something simple like carbon bulid-up in the idle air valve or a loose fast idle valve...maybe even an air bubble in coolant system. If its pointed out to the seller maybe you can knock the price down.
Old Jan 29, 2007 | 07:57 PM
HondaRacer4Vtec's Avatar
i heard thoose cars are bomb proof if properly mantianed. My dad got 300k on his still runs great.
Old Jan 29, 2007 | 09:10 PM
Tony1M's Avatar
ORIGINAL: hondadude
I second the motion, and also the water pump, seals, etc., under that timing cover.
I'd also check the struts and coil springs - just turn the wheel to both detents and look at the bottom couple of turnsof each front coil spring. Mine were cracked there and I saw another 92 having its cracked front springs changed while I was in the dealer for a failedalignment.
Also, it's real easy totry the brakes and see if there's and pulsing. Pulsing, or grabbing,would indicate warped rotors.
Good luck.
Old Jan 30, 2007 | 01:50 AM
deserthonda's Avatar
before you buy it, take it to a shop that specializes on Hondas or the dealer and ask them to do a buyer's inspection .. it might cost you 60-80 dollars but it will be well worth it
EBK142
Feb 24, 2009 11:39 AM
Antarctica
Jan 25, 2009 11:48 AM
theirishwake
Jul 3, 2007 02:15 PM
GOH10 Runner
Jan 29, 2007 02:40 AM
