91 Accord Starting issues
Old Mar 18, 2013 | 03:31 PM
philipherklotz's Avatar
Question 91 Accord Starting issues
My 91 accord at start up runs like the spark plugs are connected wrong then goes normal after 20 seconds
Old Mar 19, 2013 | 06:19 PM
I moved this from the post you put it in....
Does this seem to happen after sitting for a long period of time (say more than 3 hours). Or does it happen everytime you start the car?
Are you having to add coolant over time?
Old Mar 20, 2013 | 05:40 AM
It happens evrry morning after parked 5+ hours
Old Mar 20, 2013 | 05:48 AM
No just started doing it after i had the front subframe replaced never had anything like this yesterday it happend in A.M. n 10 sec later everyhing fine i put gas in tank only had about 2-3 gallons n added a injector cleaner concentrate and 3 gallons and it did it again then it hasnt since the last 24+ hours. The coolant is fine does leak i check it however month an half ago it was bone dry cause a hose busted so i replacd and filld it it went hot i chkd again and it was empty or 1/2 full added fluid and has been ok
Old Mar 20, 2013 | 05:51 AM
My oil though seems to split a bit quick and my gauge by speedo is red for service
Old Mar 22, 2013 | 08:52 AM
If the car has sat for a period of time then it could be the gas.
With fresh gas and the cleaner, if the issue doesn't come back...call it good.
If it does come back, let us know.
Old Mar 24, 2013 | 11:59 AM
tn6fshn's Avatar
the car turns over fine, wants to start but just wont???
mjb
Oct 15, 2009 06:26 PM
justincollier
Sep 11, 2008 09:33 AM
cumminsman
Feb 13, 2008 12:09 PM
Slowaccord
Aug 28, 2007 08:38 AM
MRMASON
Oct 3, 2006 07:09 PM
