91 accord wont start
Old May 29, 2012 | 09:42 PM
schneids1164's Avatar
Default 91 accord wont start
So ive been having trouble with my 1991 honda accord se. for awile there it would start fine but after driving and shuting off the engine it would take 20-30 min to restart. so we change the fuel relay fuel pump, it has spark. then one day it lost power and died wile i was driving it. we changed the ELD and now there is no power to the fuel pump. everything else has power but the fuel pump.
Old May 29, 2012 | 11:49 PM
Are you checking for power on the yellow wire (or yellow/black, can't remember for sure) at the 3-pin connector in the trunk?
Old May 30, 2012 | 04:05 PM
well after further inspection the ELD is showing low voltage, between .5-.75. i have looked online but cant find a place that sells them. apparently they have been dicontinued. does anyone have any ideas.
Old May 31, 2012 | 06:13 PM
I think in the audio section there is a "how to" on by passing the eld.....not sure if it is for the 4th gen or not.
Old May 31, 2012 | 06:18 PM
crispin's Avatar
I am not sure why you are messing with the ELD?
Did you have an ECU code that said bad ELD?
I have never heard of one of them going bad
But anyway here is how you bypass the ELD.
AN 820 ohm resister needs to be connected to the 2 wires with red arrows pointing at them. Then leave the ELD unplugged. I have had mine like this for a while. I run a voltage meter in my car and watch my voltage (as I have a very high amp draw car stereo system)
Here is the picture
Tony1M
Nov 6, 2023 08:29 PM
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
MrGmo
Sep 28, 2007 01:40 AM
booter
May 11, 2005 02:26 AM
