'91 accord wouldn't start in the cold temp
Old Jan 21, 2013 | 03:39 PM
Raphillips's Avatar
Default '91 accord wouldn't start in the cold temp
This morning my accord would hardly crank and never started. It was around 4 degrees Fahrenheit. It has cranked slowly in the cold before but always started with no issue. After a few attempts at starting all I get now is a rapid clicking like there's a battery or starter issue. The battery was putting out slightly less than 12 volts and some electronic components were slow to work (automatic seatbelt, radio, dash lights, etc). What could the problem be?
Old Jan 21, 2013 | 10:51 PM
A battery should hold about 12.6V. When you try to put a load on the battery, the voltage should be over 9.
I would test the battery or check the connections.
d0n
Feb 20, 2013 08:14 PM
misterix
Sep 7, 2011 08:55 AM
atom1
Jan 19, 2010 03:58 PM
Sufler
Aug 31, 2009 08:10 AM
guster900
Dec 25, 2006 09:34 PM
