91 EX usin water
Old Feb 3, 2008 | 06:16 PM
19Accord91EXlady's Avatar
Default 91 EX usin water
I got this 91 last Sept. i was told the motor was 'New' but checked the water level it was low...i put a lil less then a gallon of water in it, a noticed it was down not a ful qt. of oil..The guy told me it had bout around 12k on it..is this what a 'new' motor do? or was this guy BSing me bout the 'New' motor?? i havent took it in for a oil change yet neither..will this help at all? thanks
Old Feb 3, 2008 | 09:30 PM
Default RE: 91 EX usin water
You need an oil change since it's been well over 3 months, regardless of mileage accumulated.
Oil change won't help the coolant leak. Have a coolant system leak test performed, and if negative check for combustion gases in the coolant (a sign of leaking head gasket).
All engines take maintenance, whether new or old.
VZ2
Sep 3, 2009 12:25 PM
KUTTYSARK40
Oct 23, 2005 11:08 PM
fperezal
Sep 29, 2005 09:29 PM
jcharvolin
Sep 26, 2005 05:53 PM
joshuaaaronalpert
May 31, 2005 07:05 PM
