91 lx, check engine light, and passing smog?
Old Dec 2, 2017 | 06:37 PM
Stefant's Avatar
Default 91 lx, check engine light, and passing smog?
Hi everyone finally joined the forum!
So I have a 91 lx and have to pass smog in California. I failed the first time and that was because I had slightly high emmisions in the tail pipe test. But passing that doesn't worry me as the second reason I failed: he said the check engine light wouldn't work. I thought it would be the bulb but the light comes on for a couple seconds when I turn my key (as it should). I'm curious if anyone knows how they test to see if the light works?
Old Dec 2, 2017 | 08:32 PM
You will have to ask how they check for a working CEL. It sounds like your light is working.
Old Dec 3, 2017 | 12:05 PM
I once had a 90EX and had a failed emission for high NOX. Problem was fixed b y cleaning the EG injection ports to the intake manifold.
Sometimes a comms problem can be remedied by a reset; pull BackUp fuse for 20 secs to reset ECU/TCU.
91WagonGuy
Sep 17, 2012 10:54 AM
wwang101
Apr 8, 2011 08:36 AM
budd3
Apr 18, 2009 10:49 PM
sashkarad
May 7, 2008 09:31 PM
meazz1
Apr 27, 2006 07:41 PM
