92 Accord
Old May 14, 2008 | 03:21 PM
accord316's Avatar
Default RE: 92 Accord
Ilooked again and I don't see any other plugs. The 2 wire plug I do see is not plugged into a dummy plug. Next to the glove box hinge there aren't any plugs.
I also unbolted the mod from the floorboerd to see if there was an LED somewhere. There wasn't.
I'm wondering, since this was a transition year if they didn't move the service jack somewhere else
Old May 14, 2008 | 03:41 PM
The service jack should be in the same general area. Was the brown two pin connector plugged into anything? If not, then that should be your service connector.
Mine has a red and green wires going into it. Your wire colors may be different.
Old May 14, 2008 | 05:45 PM
poff1986's Avatar
i think if u remove underhood fuse 14 or 24 or something like that it will reset the TCU.
Old May 14, 2008 | 06:52 PM
accord316's Avatar
I found it!
I removed the glove box to get a better look into the dash. It was attached to the glovebox latch. Go figure huh?
I jumped it but no lights flashed on the inst panel. It is shifting correctly now so I think I'll have to wait till it malfunctions again as it has needed reset about a week ago. It will probably malfunction again.
Thanks for all the help! I'll check back in when it malfunctions next time.
