'92 Accord 5sp. Lurching into 1st & 2nd. Jerky idle?
Old Aug 3, 2019 | 03:32 PM
blob gnarly's Avatar
Default '92 Accord 5sp. Lurching into 1st & 2nd. Jerky idle?
I've got a '92 5 speed manual Accord. It's been running good since I
got it two years ago. Recently, however somebody tried to sabotage
it while I was on vacation, because when I got back and started
driving it again, it started acting jerky and lurching into shifts.And
not idling properly sometimes, Sputtering or rough idle. I looked
under my hood, and found that someone had attached a pair of
needle nose pliers to one of the vacuum hoses near the firewall
so that it was pinched off. I removed it obviously, and the issue
seemed to go away. Now a few weeks later, the same problem
has manifested, but much worse this time. Any ideas what is
happening? And how to correct?
Old Aug 3, 2019 | 09:12 PM
UhOh's Avatar
Welcome to forum. I've the exact same car, and I also leave it unlocked.
Unfortunately, I can't help with your mechanical tampering issue (wow); someone likely will.
Old Aug 5, 2019 | 08:24 PM
It'll probably help if you point out which hose was pinched off (cellphone photo?) Not sure I can help - not real experienced with 1992-ish Accords.
Lurching into shifts is terminology usually used for automatic transmissions not shifting very smoothly. Maybe explain what you mean by that...
letsclique
Jun 18, 2016 04:29 PM
Jake15
Nov 28, 2014 07:04 PM
hogdogs
Nov 26, 2011 08:42 AM
thedaveman89
Apr 20, 2009 08:02 AM
98accordlx
Feb 11, 2008 11:32 PM
