92 accord: can not shift without pumping
Old Apr 21, 2013 | 12:29 PM
azkitch's Avatar
I hope your clutch went faster than mine! I only took 4 months...Getting the tranny in and out were major PIAs, but in the end, things worked fine for a while...now I seem to be having hydraulic issues..does reverse bleeding cause problems for the Master Cylinder, like collapsing calipers causes in the brakes?
Old May 23, 2013 | 11:16 PM
driftdoggy's Avatar
wow ok so it was pretty bad, worse than I had thought. first off my clutch blew up jamming my pressure plate so that it would only work when I had built up enough large amounts of pressure. that in turn took out the throwout bearing and flywheel as well. luckily the flywheel was only 55 dollars. had to redo the boots on the cv axles as well so all in all I had to replace 9 separate parts lol. but in all I still only have 1400 into the whole car (purchase/parts/labor) and it runs like a champ. i'm loving that prelude swap someone did on it. thanks to everyone that offered suggestions and tried to help!
FL4T
Oct 13, 2020 11:21 PM
Hangfire79
Apr 4, 2013 07:07 AM
mdg
Jun 27, 2012 08:01 AM
dcsmith
Mar 21, 2008 07:02 PM
SIXPAK GQ
Aug 31, 2007 10:05 PM
