92 accord codes
Old Apr 17, 2014 | 06:51 PM
neighbortim's Avatar
Default 92 accord codes
Hello all, I have the code 43 and im reading in the book that its something to do with the fuel system. anyone know what i need to do to fix this problem?
Old Apr 17, 2014 | 10:48 PM
UhOh's Avatar
What does code 43 specifically indicate?, and are there driveability issues?
Old Apr 17, 2014 | 11:25 PM
Code 43 is most likely a problem with the oxygen sensor circuit ; otherwise, it may a problem in the Fuel Supply System.
See post #2 in the following thread:
https://www.hondaaccordforum.com/for...le-code-48232/
Old May 5, 2014 | 08:08 PM
Sorry guys i just got back on after having some computer problems. So anyways, whats going on is the car first start up in the morning or after its been sitting for a wile it cranks over like its not getting any fuel, also when it does start it runs good wile the engine light is on at the same time, and when leaving at a light or accelorating to get on the freeway it acts as if its hitting the rev limiter at 3500 rpms. Any help is appriciated.
Old May 5, 2014 | 08:32 PM
holmesnmanny's Avatar
check for a clogged cat ... either remove the downpipe or the oxygen sensor
Evlampius
Jun 4, 2008 12:24 PM
pturnbul
May 3, 2007 02:30 PM
larrysnach
Mar 11, 2006 10:48 PM
megaman
Mar 10, 2006 01:13 AM
rcm800
Feb 17, 2006 02:56 PM
