92 accord coupe lx auto a few different questions
Old May 1, 2012 | 04:38 PM
mixedboy88's Avatar
Default 92 accord coupe lx auto a few different questions
Ok so first issue or concern is that when i shift from park to reverse or reverse to drive (not all the time ) i hear a clunking sound liek something is loose or what not its nto the mounts as they were replaced a few months ago and transmission is fine other than that . Also while driving sometimes it doesnt accelerate as it should not a slippage though i can tell if it was slipping and there is no rpm slippage it just doesnt go as fast . i have had a full tune up oil change new valve cover gasket , a new water pump and timing belt done a new fuel pump as well . any ideas help please oh and gas mileage is only around 20mpg not quite what it should be .another issue is i dont believe i have a 17 galloin gas tank as the most i have ever put in is about 12 to 13 gallons .
Old May 1, 2012 | 06:46 PM
Is there "slack" in the cv joints?
Any stored codes in the TCU/ECM?
Old May 1, 2012 | 07:23 PM
mixedboy88's Avatar
i dont know that for sure but is that a possibilty . and idk about the codes
Old May 2, 2012 | 06:42 PM
There is a write up in the Common DIY THreads sticky at the top of this section that will tell you how to get the codes and how to read them.
Old May 3, 2012 | 12:17 AM
deserthonda's Avatar
did issue happen after timing belt job?? if so ,,,have the tech recheck the cam timing and the balancer shafts timing
Jeffambo
Jun 19, 2012 11:19 PM
uhh what
Jun 5, 2011 11:31 AM
masterbarber
Nov 6, 2010 08:55 PM
ownage786
Nov 10, 2007 12:41 AM
kriegz99
Aug 11, 2007 08:41 AM
