92 accord cruise control
Old Sep 7, 2012 | 02:15 AM
zedjr's Avatar
Default 92 accord cruise control
i have 1992 honda accord ex 2.2 litre. I push cruise control main switch and it lights up. I then push accell and the green dash lights ups also. But cruise doesnt engage. I figured it was servo/regulator. Any help is appreciated.
Old Sep 7, 2012 | 06:38 AM
UhOh's Avatar
welcome to forum ...
Originally Posted by zedjr
... I then push accell ...
have same year, model.
You're pushing the top of two control buttons on the steering wheel.
The lower one (maybe the letters are worn off?) is the one to set the speed - "SET."
So to set the speed push the lower "SET" button rather than the top "RESUME/ACCEL" button.
Old Sep 7, 2012 | 09:56 PM
zedjr's Avatar
yes i try both buttons and in many different ways but the servo wont engage.
Old Sep 8, 2012 | 09:09 AM
Since you have had the car - has it ever worked?
Auto or manual trans?
Auto trans - you'll want to test the brake light switch.
Manaul trans - test brake light switch and clutch pedal switch. There are two - one is closed when the pedal is not being pushed, this is for the crusie. The other closes when you push the pedal down, this is for the starter.
Also check the vac lines to the can and the servo.
Old Sep 9, 2012 | 11:37 PM
zedjr's Avatar
its a manual and yes i have allready checked brake light and other. the vac lines to the can i dont know where that is or how to check?
Old Sep 10, 2012 | 06:15 PM
Did the cruise ever work since you had the car?
The switches showed what on the volt meter when tested?
The vac lines are just that, hoses connected to the "can" and to the intake.
Have you checked the fuse?
Is the CEL on or come on recently?
Old Sep 12, 2012 | 04:14 PM
Sundevil81's Avatar
Okay, this is somewhat along the same lines....I cannot get the master cruise control switch to glow green and therefore no cruise control light comes on the dash...all fuses appear to be good and brake lights work fine. On a 5-speed should I be checking the switch behind the clutch pedal?
DrBones
Jan 10, 2008 06:02 PM
aatc20
Sep 25, 2006 04:28 PM
alfredo123
Jul 24, 2006 01:09 AM
toka
Apr 1, 2006 06:12 AM
rabbit
May 3, 2005 01:28 AM
