92 accord front brake rotors
Old Aug 1, 2009 | 09:26 PM
tmac7175's Avatar
Default 92 accord front brake rotors
I have 92 accord LX sedan, the front brakes are toast! I need to get the front rotors off but, not sure how to do it. I took the caliper off and what was left of the pad. that's right just one pad left in there..there's an axle nut that I'm not sure if it needs to come off and do i need to take apart the whole back lower ball joint steering knuckle and so on.. my first time doing anything like this.
Old Aug 2, 2009 | 10:47 AM
Tony1M's Avatar
I recommend that you yuy one of these, or find a place that uses it:
https://www.hondaaccordforum.com/for...ighlight=rotor
It is necessary to remove the axle nut and that can be very difficult. You might want to take the car to a shop, have them loosen it, have them tighten it to spec., then take the car home and the nut should come off rather easily.
Good luck. Let us know how it goes.
Old Aug 3, 2009 | 09:36 AM
Moving this to General Tech where it belongs.
Old Aug 4, 2009 | 01:33 PM
tmac7175's Avatar
So far after three days I have still not been able to get the hub off the drivers side! took everything off the back like the book shows, sprayed it with penetrating oil and it still won't come off. Any ideas? I spoke with a mechanic friend of mine in another state and he said like everyone else has that once you dis assemble everthing and take four bolts out the back it would come right out. not so..
Old Aug 4, 2009 | 01:45 PM
Corrosion? I bet you can find cars in Arizona or Saudi Arabia that after 17 years still have bare metal that's not rusted. I have a feeling that's one reason why people have such different experiences with their hubs & bearings.
Old Aug 5, 2009 | 11:36 AM
tmac7175's Avatar
Finally got the hub off!!!! had to take the whole hub, rotor, steering knuckle and a friend took it to work and pressed off hub. got it mostly back together. the castle nut for upper ball oint is stripped so, getting new one today. the new caliper i bought the brake line won't fit in the slot so I have to file or dremmel it out to fit. thanks for all the help.
TMAC
cunningmc
Aug 6, 2011 10:33 AM
J2Performance
Jan 25, 2008 01:02 PM
J2Performance
Jan 15, 2008 12:45 PM
benjiaccord
Mar 20, 2007 10:21 PM
deserthonda
May 12, 2006 04:06 AM
