92 accord front hub flange bolts
Old Sep 1, 2013 | 01:29 AM
drifterz73's Avatar
Default 92 accord front hub flange bolts
ok i tried to remove the outer flange bolts on the pass hub and started to strip.. are there good replacement flange bolts out there WITHOUT going to the stealership!!
Old Sep 1, 2013 | 07:19 AM
Can you pick out the bolts from this pic?
Attached Thumbnails 92 accord front hub flange bolts-4th-gen-front-brake.jpg
Old Sep 29, 2013 | 12:49 AM
superdesi's Avatar
I ran into this recently. I thought the axle nut was going to give me trouble but it turned out the hub flange bolts got stripped.
The best bet is the stealership because they will be right length. My bolts are completely rounded off so I'm still deciding on how to remove them.
BTW, its number 22 in the photo above.
Old Sep 29, 2013 | 01:57 AM
Honda-Master's Avatar
Hit the top of the bolts with a hammer to flatten them up a bit,,once done that best way is to use a 1/2 inch drive 6 point 14 mm impact socket , make sure socket fits snug .if loose hit bolts a bit more , then use an impact gun ..By the way get the new bolts from dealer , bolts have to be the right length,or you will have issues
Old Sep 29, 2013 | 02:20 AM
superdesi's Avatar
Yes....absolutely solid advice. I made the mistake of using regular sockets with an impact wrench. It's worked in the past but this time it just rounded them off.
I will try the hammering them in the center trick. Thanks.
93Accord2.2
Oct 20, 2014 07:31 AM
Tony1M
Nov 6, 2013 12:11 PM
JMH
Mar 7, 2011 11:15 PM
Castor Troy
May 18, 2007 05:38 PM
stratijikal
Jul 29, 2006 03:31 AM
