92 Accord Owners, Common Refrigerant Leaks ??
Old Jan 29, 2011 | 02:50 PM
dunnskii's Avatar
Thumbs up
The tubing connections in the evaporator housing. Evaporator housing must be removed, split, and opened to access/replace the orings. You can get an accord oring kit from ackits.com, ebay, or match them after removing.
Leaks will be indicated by dirt/oil accumlation around the connections and on the evaporator.
Clean connections w/ plastic brush and light use of fine steel wool to remove corrosion and polish, but not scratch the sealing surfaces.
AC repair can be rewarding, but it must be done right. Read autoacforum.com for tips on ac work.
Thank ya Sir... Ya, Im acutally EPA Certified HVAC/Piper fitter(union). I was into Commercial Refrigeration,HVAC, Service and Repair for 15 years... But I got hurt, broke my Back on a Job, Thats why Im a Disabled Dude...But like most things, Cars are a bit different, and they scare the HELL outta of me...lol Was planning on pulling the Evap and Blower, but not till it stays warm for awhile...They replaced the Compressor, but it came outta 91 accord, mines a 92, So I dont kno what Refrigerant they used, or if the changed the Exp. Valve, Im assuming they upgraded some thing due to the fact that service ports are 134-A, And would a old r-12 comp work with 134-A, when did cars switch from R-12 ??? Or maybe they used that "Hot Shot" that suposed to work with anything ???...Who knoz, but I guess Ill find out soon...Its crazy what some ppl do, when they think they kno what they are doing ! Ima gonna degrease and clean all visible connections for starters, then wait till spring to really get in to it...I got No Garage... Thanks for the Info Tex ... Dave...oh, Is the Evap aluminum or steel, seem to have a mix of pipes 1 or the other, but they are all dirty as hell , so I dont know what I got just yet !!!
Old Jan 29, 2011 | 05:26 PM
dunnskii's Avatar
Thumbs up Wow...
Found 3 leaks today... 1. there was no schrader valve in the High Side access port (quick connect)... 2. found tubing connections at Accumulator loose, 3.leaking at High side Pressure switch... Next stop, Evap, and TXV Valve(Expansion Valve)...But waiting on that till its warm again. Got some bad weather comin my way...Ima gonna have to pull one hell of a vacuum on this system, Im sure its full of all kinds of uncondensables...Got great air flow, but who knowz wut the dude I bought this car from had done......
Old Jan 29, 2011 | 05:46 PM
If you are going to take apart the a/c, I would replace every o-ring in the system. I'd probably replace the Styrofoam inside the evaporator as well.
I am not sure if your accord had R12 or R134a, but I think that it is R12.
If you want to convert to R134a, you will have to drain out all of the mineral oil, clean the system, then add the proper amount of ester oil. You will have to convert the High/Low adapters to R134a sizes. I am sure there are some other things that I forgot to mention.
The point is that you want to do this right first time to ensure you will not have to open up the system for a long time.
Old Jan 29, 2011 | 06:10 PM
dunnskii's Avatar
Default Ya... Thats what is confusing...
the fact the the comp is a 91, mine is a 92, so right there they have got into the system, 2, the fact of the access ports are for 134-a...Some one would have had to put those in upon changing refrigerant, and comp...I think what ima gonna do is, once i get to the Fan/Evap, area, see what the Expansion valve is and go from there, I kno for sure that a TXV Valve for r-12, wont work very well for a r-134-a system...LOL, typical of this car... Guy I bought it from was a oil field worker/ Thought he was a Honda Mechanic...lol... Another long process to figure out what was done...R-134-A came out the year I got hurt, So its foreign to me...That what gets me the most, ps, found a sticker under hood that the system was changed to r-134-a, but with that old comp, I just dont kno, Dude said the A/C works but just needs a charge... Ya... I bet . LOL... Guess I lll find out...
Old Jan 29, 2011 | 10:01 PM
A new receiver/drier is a good idea also. Check around the compressor clutch rotation plane for an oil/dirt accumulation ring from slung-out oil from compressor. This would indicate a leaking shaft seal. Good used compressors are readily available from ebay or car-part.com.
Old Jan 29, 2011 | 10:12 PM
dunnskii's Avatar
Thumbs up kk
So what I called the accumulator, u call a reciever, that part is also a Drier ??? Yah, I will change that out for sure then...That will do nothing But HELP the entire closed loop, wuz wondering about that...cool, now I kno...ty very much for your input....Sure appreciate it ! ...Dave... Another question, the Expansion Valve should be marked as to what type of refrigerant it is for, right ???
Old Jan 30, 2011 | 08:47 AM
  #17
Actually, I've never done a conversion, only maintenance on existing systems. I've read (autoacforum) that changing the expansion valve is not necessary. I doubt they are marked other than part numbers. Suggest a bit of research at that source for R134a conversions.
Most posters seem to say that retrofit of the early 90's Accords will produce adequate but not spectacular cooling. This seems likely since they were'n that great w/ R12. I bought a partial-filled container of R12 when all this conversion hysteria started. That lasted until I sold my 90 Accord several years back.
Old Jan 30, 2011 | 09:34 AM
  #18
dunnskii's Avatar
Yah, Ill do some checking. In Home/Building HVAC and Refrigeration, the expansion valve is key to correct operation, but Now a days they have other ways of actuating the refrigerant flow...Thanks for all the info, now I just have to wait for awhile, Thats my spring project !...lol
tashier
Apr 3, 2012 06:33 PM
mikentn
Dec 12, 2011 12:54 AM
dunnskii
Mar 7, 2011 10:44 PM
bjr001
Dec 1, 2010 06:44 PM
reeling
Aug 27, 2008 10:53 AM
