92 accord power steering help needed
Old Jan 18, 2016 | 07:20 PM
Apotack's Avatar
The seals stopped the foaming. I hosed out the reservoir with brake cleaner several times then rinsed with steering fluid.
I will check the suction hose.
Old Jan 19, 2016 | 10:49 AM
If it's not foaming any longer, then I don't think the problem is related to air sucking in anywhere.
Old Jan 19, 2016 | 12:39 PM
Apotack's Avatar
Any thoughts on why it's so hard to turn?
Old Jan 19, 2016 | 03:03 PM
Not really.
Can you rule out steering-column alignment and excessive friction up in the steering column? I hate to say that might require disconnecting the steering column down near the rack (easy for ME to say) to see whether the difficulty is in the rack or pump at all.
Old Jan 19, 2016 | 03:49 PM
Apotack's Avatar
It's odd because other than the foaming the steering was fine prior to replacing the pump seals. I opened and cleaned the valves on the rack I'll see how it is when I have the car back on the ground, hopefully by tomorrow.
Old Jan 19, 2016 | 04:11 PM
If the steering feels light & easy with the engine turned off and the front wheels raised off the ground, then its not a steering column problem.
If the valves are messed up inside the rack, that might explain the steering not having any power-assist. Not sure how you'd check those out. I've never rebuilt the internals of a rack.
Old Jan 19, 2016 | 06:44 PM
  #17
Apotack's Avatar
Ok thanks. I'll figure it out eventually
Old Jan 29, 2016 | 01:43 PM
  #18
Apotack's Avatar
Default Update
Replaced the ps pump, no change.
Old Jan 29, 2016 | 02:12 PM
  #19
Is PS fluid foaming on return to reservoir? If no and fluid is circulating, then PS rack may be the problem.
loki16
Aug 12, 2013 06:54 AM
darkgreen18290
Jun 25, 2013 07:51 AM
Jmurr89
Feb 10, 2013 03:23 PM
svleonard
Oct 22, 2011 09:53 PM
Planefreak
Nov 15, 2007 02:52 PM
